Are all amp hrs equal?
Gjac
Say you have 230 amp hrs in 2 6vGC batteries and you discharge at a low amp rate say 1 amp so if you discharge to 50 percent SOC you should have used 115 amps in 115 hrs. If you then discharge at a higher rate say 10 amps would it then take 11.5 hrs to get to 50 percent SOC? Or does the higher discharge rate create more heat and loss occurs during discharge causing batteries to have less amp hrs?
20 REPLIES 20
Gjac
I assumed this loss in amp hr capacity was due to heat. If this is true, can one also assume that these higher discharge rates producing more heat also reduce battery life every thing else being equal (still only discharging to 50 percent)?
gbopp
BFL13 wrote:
Yes they are all equal. How many you get out of a battery "depends."
Google "Peukert's Law"
Peukert's Law
Interesting, thanks.
Chris_Bryant
Pretty much the same as fuel mileage- floor it and you get less.
-- Chris Bryant
BFL13
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
mike-s
The lower the rate, the more amp-hours you'll get, except at the very extreme where battery self-discharge comes into play. Trojan, for their T-105, shows these specs:
5-Hr Rate 185
10-Hr Rate 207
20-Hr Rate 225
100-Hr Rate 250
red31
the 230 ah should be based on 20 hr discharge or a constant 11.5A
lower/slower discharge yields more ah
higher/faster discharge yields less ah
