I have two hydraulic slides that operate simultaneously. One slide is not opening completely. I suspect it is pressure related. Are these limiter/regulator hydraulic valves? If so any suggestions on how to adjust so the one slide opens completely. Also, I have the hydraulic leveling system. Not sure what to do here.
If you have one slide that is not fully opening I’d suspect you need to check the adjustment for its open travel position.. Very easy to do... just download the Lippert manual for your hydraulic slide out and look at the slide adjustment section.. complete with pictures.
Those two valves are there so that you can select an individual slide you want to open without opening the other... normally used if you want to only open curb side slide to get at a fridge..etc
They have nothing to do with pressure.. Normal position would be fully open for both
If I recall correctly one is for each slide and you can disable individual slides using those. Maybe you want to ensure they are both open all the way first or close one and try the other?
