Water hot...........normal t-stat opens at 140*F
Water really hot....ECO (high temp t-stat) opens at 180*F
Water temp needs to drop to 110*F or lower for either t-stat to close
IF ECO opens...you should get 'Fault light' at On/Off panel. Must turn off then back on to reset 'fault' (Does light work??)
Atwood 91447 is correct t-stat/ECO replacement
