โJul-19-2020 06:54 PM
โJul-20-2020 09:25 AM
โJul-20-2020 09:08 AM
time2roll wrote:I can try that, however if that were the case, wouldn't the problem (shocking) continue after removing the Autoformer?
I suspect either reverse polarity at the pedestal or more likely a poor ground connection and your RV has a small current leak to ground.
Assuming you are back at home... consider plugging the RV into a GFCI outlet and see if it trips.
โJul-20-2020 08:53 AM
rfaulkner99 wrote:I suspect either reverse polarity at the pedestal or more likely a poor ground connection and your RV has a small current leak to ground.
However, at some point my daughter got a little bit of a shock on the metal door handle and I thought it might be the Autoformer so I unplugged it and it went away. That is when I noticed the corrosion/melting on the plug.
โJul-20-2020 08:04 AM
โJul-20-2020 04:07 AM
โJul-19-2020 08:19 PM
โJul-19-2020 08:06 PM
โJul-19-2020 07:29 PM
โJul-19-2020 07:18 PM
