Can someone tell me where backup light switch is located on 2007 V10. Thanks Ray
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
The Ford 4R100 tranny used with the V10 powered F53 chassis has the B/U switch on the transmission, as does the E40D used with the earlier 460 V8.
On edit: I should mention that the part is called the "Transmission Range Sensor", and also serves as the neutral safety switch along with other functions. It has an eleven pin connector.
Dutch 2001 GBM Landau 34' Class A F53 chassis, Triton V10, TST TPMS Bigfoot Automatic Leveling System 2011 Toyota RAV4 4WD/Remco pump ReadyBrute Elite tow bar/Blue Ox baseplate
Should screw into the transmission. I've replaced 2 before. One on an Isuzu pick up and one on a Toyota Celica. Look for 2 wires coming from a fitting on the side or near the rear of the transmission. When shifting the transmission something in the transmission associated with reverse engages the switch.
