Batteries
Colo_Native
Everything is done with the inverter and solar now on to the batteries, I have 2 1 year old group 27 12v about 90ah each. should I just buy another since they are new or should I up grade to GC batteries or something else? I would like to keep the weight down
2015 Winnebago Forza 34T
pushed by a 2011 Fusion Hybrid or 2020 Escape Hybrid
Retired DFD
14 REPLIES 14
corvettekent
Colo Native wrote:
corvettekent wrote:
With 510 watts of solar you should have a lot more storage (battery). How big of inverter did you install.
Magnum 2812
That's a nice big inverter. You could try adding just one more battery but you should add two.
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Boon_Docker
What would be really ideal for your solar would be 4 GC's giving you about 460 ah, but you say you are concerned about the weight.
Colo_Native
2oldman wrote:
If you want to really save weight, go Lithium. Your wallet will lose a lot weight too.
I would rather keep it in my wallet
Retired DFD
Colo_Native
JiminDenver wrote:
I would add a third Grp 27 to the other two. It should be fine unless you beat the snot out of the originals. That way you get more usable Ah's, less voltage drop under load and less expense right now. By the time you need to replace them again you should have a good idea what direction to go.
Jim that's kind of what I was thinking
Retired DFD
Colo_Native
Magnum 2812
Retired DFD
JiminDenver
2011 GulfStream Amerilite 25BH
2003 Ford Expedition with 435w tilting portable/ TS-MPPT-45
750w solar , TS-MPPT-60 on the trailer
675 Ah bank, Trip-lite 1250fc inverter
Sportsman 2200w inverter generator
corvettekent
2oldman
2oldman
brulaz
You mentioned an inverter.
3-4 Grp 27 batts might have less V drop under high loads than a pair of GC2s. Depending ...
2014 ORV Timber Ridge 240RKS,8500#,1250# tongue,44K miles
690W Rooftop + 340W Portable Solar,4 GC2s,215Ah@24V
2016 Ram 2500 4x4 RgCab CTD,2507# payload,10.8 mpgUS tow
time2roll
With two perfectly good batteries I would connect one even two more as needed.
With proper care they should serve you well another 5+ years.
Boon_Docker
I would go with 2 GC's.
That would up the ah from 180ah to 230ah with just 14 lbs more weight.
Colo_Native
MrWizard wrote:
did you assay your use?
good batteries are heavy
of your biggest concern is weight just keep what you have GCs or other good batteries will weigh more
1. yes about 150ah
2. these are 53 lbs each
looking for a little more ah currently 180 ah just finish the install so I don't have a real world test.
Retired DFD
MrWizard
Moderator
Moderator
I can explain it to you.
1997 F53 Bounder 36s
