โJul-30-2013 09:26 AM
โJul-30-2013 10:03 AM
jgkurz wrote:No. Breakers are designed to allow some surging before tripping.
If it was truly 30amp surge wouldn't that trip my 15amp breaker?
โJul-30-2013 10:01 AM
โJul-30-2013 09:51 AM
smkettner wrote:
That a/c is 10.5 amps at 120 volts. 1260 watts + 10% overhead and some power factor puts you right at the inverter max. Batteries are providing 120 amps and you need 4+ to get any reasonable run time.
BTW what size and length is the 12v wire? 5' of 2/0 would be about my minimum rating.
โJul-30-2013 09:45 AM
โJul-30-2013 09:42 AM
2oldman wrote:
No. You'll need at LEAST 4 batteries to handle any a/c load, and even then it will be for maybe 15 minutes max.
The startup amps for the compressor are possibly in the 30amp range, meaning 300a from the batteries. That's what your two batteries can't handle.
โJul-30-2013 09:29 AM
