โMar-01-2017 01:11 PM
โMar-02-2017 05:03 AM
MEXICOWANDERER wrote:
I would rather put the limit at 15 volts because no automotive voltage regulator meaning alternator control is going to top out less than 14 volts unless the alternator warms up and the thermistor within the voltage divider network starts ramping control set point downward. Most Delco and Ford integral regs commonly start out in the 14.2 - 14.4 range at 25c. Motorhomes traveling long distances will arrive at set point limit for hour after hour. Hard to keep the Hatfield chassis batteries satisfied with a house battery diet and verce-visa.
โMar-02-2017 04:45 AM
โMar-02-2017 02:46 AM
Mandalay Parr wrote:
Everything stays attached to the batteries. That is the proper design.
No damage is done.
SoundGuy wrote:
Not true at all ... equalize @ 16 volts and you could easily expect to see some smoke. :E
MrWizard wrote:
No Body was talking equalizing
that is a special situation, where things should be dis-connected
before doing it
BUT that is NOT normal operation
โMar-01-2017 07:33 PM
No damage is done.
โMar-01-2017 07:16 PM
โMar-01-2017 03:25 PM
โMar-01-2017 03:11 PM
No damage is done.
โMar-01-2017 02:31 PM
โMar-01-2017 02:20 PM
โMar-01-2017 01:45 PM
โMar-01-2017 01:37 PM
โMar-01-2017 01:16 PM
