Battery in Michigan winter ?
joesann
Just picked up our new 5th wheel. Was wondering what to do with the battery for the winter? Should I remove the battery from the coach and keep inside till spring? Thanks for your responce
26 REPLIES 26
rockhillmanor
Lwiddis wrote:
โ€œTrust me taking them out and bringing them inside your house is the way to goโ€
Why, Rock, if you can keep them charged? 85 percent charged freezes at minus 67 degrees F. See http://www.trojanbattery.com/pdf/WP_DeepCycleBatteryStorage_0512.pdf TRUST ME!
When I winterized, I started the MH every week and if no snow tried to drive it at least every two weeks. Not hooked up to any shower power. And I took the coach battery out.
I never used a trickle charger on it because previously on 2 occasions the trickle charger overheated the cords. IMHO after that for safety reasons I refuse to use them anymore......sadly they are all made in china and cheaply made now not at all like the ones back in the day.
MEXICOWANDERER
A battery company asked me to help a distributor titrate a hot shot specific gravity for new batteries headed for Prudhoe Bay AK. To prevent the batteries from freezing when at 50% state of charge. It takes some fierce kind of cold to freeze a battery. Colder than anything in the lower 49.
Preventing any type of unintentional discharge is the key. A battery with a dead cell can freeze that cell. Sort of like machine gunning a corpse.
cdru
I live in Northern Minnesota. The trailer batteries and the two pontoon boat batteries all get fully charged and disconnected for the winter and left where they are. They are outside from the first of October until April without any problems. Been doing this for many years and have never had one freeze. cdru
time2roll
MEXICOWANDERER wrote:
Definition of "Disconnected" either battery terminal with zero wires connected to it.
Yes and the case needs to be clean. The sludge on top is often plenty to run it down in storage.
MEXICOWANDERER
Keeping the battery in the rig or six inches off a cold floor is not considered extreme high-tech.
babock
Would be interesting to actually do a temp test of a battery case gradient. If temp between slab and air was 20ยฐF difference, I wonder what the gradient of the case would actually be. Of course, if you actually put a charger on there occasionally, that stirs up the electrolyte and there wouldn't be an issue.
Dave_H_M
2oldman, now that was a classic answer.LMBO B stands for butt which sounds more cooth. :B
MEXICOWANDERER
This was a finding, not an accident.
750 ml measuring column. Pyrex. 300 mm tall
Fill with new electrolyte. Titrate to 1.280 SG adjusted to 20c.
Place on concrete slab. Temp 10F - 30F
Air temp at center of column 50F - 75F
Temperature quickly fell as thermocouple temp was lowered center of column to floor but was never less than 12 to 15 degrees warmer than the concrete. There was no fan air movement present.
Sample reposed for (Cannot remember exact time but around three months).
However I do remember the final gravity as being 1.205 top 20 mm.
Opinion. Even though it sat in a relative temperature gradient the effect was clearly defined. The test was conducted off-site in an unused garage
A few years later, I measured the same column (stoppered) for a year at 40-90F and found an inconsequential amount of gradient differential.
Apparent is the evidence that Delta T between concrete pad and air temperature is key. Not the temperature itself.
babock
A floor that is + 40F and air that is 70F encourages stratification of electrolyte.
That's interesting...have any links that talk about that?
Sounds like keeping them on a charger and doing equalizing charges nullifies that correct?
MEXICOWANDERER
Nothing like actually testing theory: ๐Ÿ™‚
A floor that is + 40F and air that is 70F encourages stratification of electrolyte. This is anything but a black and white issue. The stratification is much amplified when tall batteries are involved. But place a car jar battery in such an environment for four months and stratification will be enough to "matter". The cure is absurdly easy so this shouldn't even be an issue.
Battery type and age enters into the self-discharge picture. High antimony batteries will self discharge about 150% the rate of car jar batteries. Calcium calcium starting batteries will discharge at less than 1% per month at -20F
Old batteries near death can discharge 20%+ per month. This is due to the nemesis of negative plate antimonial contamination.
There is nothing wrong with using a maintenance charging source. However if a lot of money, time and hassle is involved just to maintain batteries for a few cold months then common sense dictates the issue should be analyzed. A decision can be skewed by the additional need to maintain batteries in warmer weather due to infrequent use.
2oldman
It's worse for the concrete floor than the battery when acid spills on it. But somehow this old advice just never dies, like cats smothering babies.
wa8yxm
3 answwes.
1 a FULLY CHARGED battery is good all winter in MI.. However if the battery is just sitting there. even disconnected physically, it will loose charge (Self discharge) over time.. So you need to keep a tender on it.
2: If your RV has a good quality 3-stage converter.. Plugging in will "tend" the battery
3: If you disconnect and bring into the house/garage (where you have power for the tender) BEFORE you unhook take two small cans of spray paint, One red, one black, Spray the wires hooked to the POSITIVE terminal RED.. Black on the negative
If more than one wire is hooked to either Red or Black, tape or tie them together (String or zip tie) one for red one for black.
Insulate the RED wires (Wrap with plastic wrap or tape)
owenssailor
I keep my trailer batteries safe over the winter by taking them South in the trailer.
My boat batteries get to stay home here in Ontario where it gets very cold. For the last 30+ years I have charged them in Nov, disconnected them and checked them in Apr. No problems.
I know one guy who had a trickle charger on his boat batteries. The power cord got disconnected and the charger became a load that ran his batteries down. Two of them split spilling the electrolyte into the bilge. Bad.
Also - the concrete myth is a left over from batteries from the 1940's 1950' or earlier. It does not apply anymore.
2011 Jayco 28U
2012 Chev Silverado Crew Cab 5.3 6 spd 3.42 (sold)
2017 Chev Silverado Crew Cab 5.3 8 spd 3.42
Equal-i-Zer 1400/14000
RotoChocks
babock
John&Joey wrote:
I don't doubt you, but at $70 to $90 a piece I'll stick with best practices. Was nice you were going to store his battery on your concrete floor for him though
Its actually not a best practice anymore. Probably actually better to have it on a cold concrete floor. It will discharge less since it is cooler.
