Feb-10-2023 10:06 AM
Feb-14-2023 04:58 AM
Feb-13-2023 05:06 PM
Gjac wrote:jjrbus wrote:This is one way that is simple, another way that you probably have built into your chassis already, is to turn your key to ACC and that should combine both batteries. While plugged into shore power check both batteries to see if you get 13 plus volts.
I do not understand why I would add a solenoid? Wouldn't I add a wire between the 2 battery terminals on the isolator with an inline 12 volt
switch??
Feb-13-2023 04:35 PM
Feb-13-2023 05:34 AM
Feb-13-2023 04:16 AM
Feb-12-2023 01:24 PM
Feb-12-2023 11:08 AM
Feb-12-2023 07:02 AM
switch??
Feb-12-2023 06:55 AM
pianotuna wrote:
Hi,
I added an addition solenoid rated at 200 amps continuous. For the starter battery I added a Trik-L-Start. Today I'd chose a dc to DC charger.
Feb-12-2023 05:05 AM
switch??
Feb-12-2023 04:51 AM
Feb-12-2023 03:28 AM
Feb-11-2023 07:23 PM
switch??
Feb-11-2023 05:22 PM
Feb-11-2023 05:39 AM
