โOct-09-2021 08:40 AM
โDec-25-2021 12:09 PM
DD716TED wrote:No need to adjust the voltage. Should work out of the box just fine.
I am replacing the MBA in my WFCO WF-8955PEC power center with a Boondocker BD 1255MBA 55 amp, 4 stage MBA. No instructions came with the Boondocker unit however, I believe it is the same as the "Powermax" PCMB-55-MBA. I found some instructions on INET for Powermax, but they are very poorly written and make little sense. Installing the circuit board and associated wiring is a breeze, but the instructions on how/when to adjust the fixed voltage circuit switch/potentiometer are a joke.. they jump all over.. Has anyone installed this particular Boondocker board and did you even bother to adjust the "fixed voltage"? or maybe even a better question, did you find better instructions on how to do it?
โDec-25-2021 11:25 AM
โNov-28-2021 10:38 AM
DD716TED wrote:
Thank you for the response..The one question I have is.. when installing the circuit, do you only connect the AV 115v.. then adjust the switch/potentionmeter to the correct DC Output, then turn off AC ,then connect the battery / dc circuits (fuses), re-energize AC and check that all is working properly..thanks again for your help..
โNov-28-2021 09:45 AM
โNov-27-2021 06:59 PM
โNov-27-2021 06:07 PM
โNov-22-2021 03:05 PM
โNov-22-2021 03:01 PM
โNov-22-2021 12:52 PM
โNov-17-2021 05:34 PM
BFL13 wrote:DD716TED wrote:
Thanks for all of the responses.. Tested batteries..they were failing.. replaced with new batteries and all is well..
__________________
All is not well unless you found the converter issue reported in the OP.
If the converter was working, the voltage would have stayed at 13.7ish the whole time, and you would not have noticed anything about
the condition of the batteries.
โNov-17-2021 04:36 PM
DD716TED wrote:While it sucks you are having problems, just get a battery charger and hook it up to your batteries. That is basically what a converter is anyway. That will buy you time until you get a replacement for the WFCO. I would recommend a Progressive Dynamics.
I previously reported all was well BUT it is not. A recent camping trip
showed me problems again. New batteries seemed at first to help but that was incorrect.. Same thing started to happen again.. With nothing turned on, batteries connected and pedestal power applied, DC Voltage read 13.6 VDC. Then within 30 seconds of turning on
either the water pump or furnace, everything dimmed or slowed down..
I the disconnected batteries and again applied pedestal power to the trailer.. as long as nothing (pump or furnace) was on DC Voltage remained about 13.5 vdc.. The minute I turned on wither the pump or furnace, DC voltage dropped to 7.5vdc, overhead lights flashed on/off and furnace or water pump started rapid on/off cycling...
Given this, I now believe the WFCO WF-8955PEC has failed failed and needs a new power converter circuit assy. Am now searching for an exact fit / drop in replacement power converter circuit assembly at a reasonable cost.
โNov-17-2021 02:41 PM
โNov-17-2021 12:32 PM
โOct-11-2021 02:23 PM
__________________
