Battery Percentage Before Charging.
1L243
I was wondering what the consensus is on what your AT REST battery level of charge is before you feel you MUST get in on the charger? Understanding percentage may vary depending on type of batteries.
2017 Coleman 300tq by Dutchman Toy Hauler. 34.5 feet long and under 10k Gross. 500 watt Solar 2000 watt Inverter, 1999 Ford F250 2WD 7.3 4R100 DP Tuner, S&B Cold Air Intake, Gauges, 6.0 Trans Cooler, Air Bags.
11 REPLIES 11
1L243
I just spoke with the research and development department (me) and it was decided to postpone the low voltage test to prevent unnecessary damage due to sulfation.
We will be having real world testing soon enough..
Thank for the input..
time2roll
Yes leave a couple lights on. If you discharge extremely slow you may count more amp/hrs compared to when you are actually using the RV. The small draw you post is virtually at rest so the battery scale of voltage is a bit different. Such as 12.06 might be 50% in normal usage but would be only 25% charge in your virtual rest experiment.
The 12 Volt Side of Life
BFL13
Drawing them down slowly means that whole time they are below full they are sulphating. Sulphation hardens over time so it becomes more difficult to desulphate and after a longer time impossible.
IMO do the test with a higher amp load and get it all done in less time, so you can recharge sooner.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
1L243
My Trailer is in covered storage so no sunlight for the panels.
I'm in the process of watching my shunted battery monitor slowly come down from the little parasitic loads inside the trailer. at a 0.01 percent draw it might take a while.
I'm doing this on purpose so I can get a understanding on the accuracy of the battery monitor. It's been about 10 days now and the battery is currently showing 12.5 volts at 97% capacity. I set the monitor after charging fully then resting for 4 hours at 100%
The monitor can be set at 100% if fully charged or at 0% if dead. Not wanting to discharge my batteries fully I chose the 100%. But I did read somewhere that setting at 0% percent then letting the batteries find 100% when fully charged might be a more accurate setting?????
I'm thinking 12.2 volt will be as low as I will go with the test. Under normal circumstances I usually don't go below 12.3 volts
BFL13
corvettekent wrote:
This way a shunt based battery meter is so much better than reading battery voltage. When I checked this morning I'm at 81% SOC. My voltage is 12.2.
My batteries started charging when the sun came up.
That is a warning sign that your AH counter needs to be zeroed (when the batts are truly full), or else the 12.2 was a loaded voltage at the time with the furnace running perhaps.
Cross-check the SOC from AH counter with the voltage before solar starts raising the voltage and when nothing much is on early in the morning (so close to resting as it gets when camping) regularly to see when the monitor's AH counter is getting out of whack.
Photo in Profile
corvettekent
2022 Silverado 3500 High Country CC/LB, SRW, L5P. B&W Companion Hitch with pucks. Hadley air horns.
2004 32' Carriage 5th wheel. 860 watts of solar MPPT, two SOK 206 ah LiFePO4 batteries. Samlex 2,000 watt Pure Sine Wave Inverter.
Lwiddis
Depends on how many cycles you want from your batteries. The deeper the discharges, the fewer the cycles. With a solar system your issue would be largely academic. Sun isnโ€™t quite up yet but solar is giving my batteries some charge regardless of their SOC.
time2roll
12.2 is not too soon to put a charge back in. 12.4 is OK to charge some depending on expected usage overnight or such.
Gjac
While camping I recharge at 50% which takes about a week. At home when the batteries reach 80% I recharge.
BFL13
My idea is to use an electric toaster in the morning, so I need enough battery to run the inverter without it shutting off from low voltage.
So once you know your voltage drop from running the toaster, say 0.6v (you will have your own number), and knowing what the inverter's limit is (11v?) that means before you turn on the toaster, battery voltage must be at least 11.6 plus a bit, call it 12v. That happens to be about 40% SOC with mine.
Playing it that tight, you have to turn off the furnace first for a few minutes, so it does not come on and kick off the inverter before the toast is made. Later that morning, out comes the generator.
Photo in Profile
JimK-NY
12.2 volts is roughly 50% discharge. I don't like to go below that. At that point I am down 150 AH on my 300 AH bank so that means a lot of charging will be needed. Three hours of charging will only get me to about 90%.
