hellbird503's avatar
hellbird503
Best way to clean ceiling
Had a leak from ac unit, now ceiling has a few stains,what is the best way to remove stains? Have tried tuff stuff and goop, didn't seem to help. Thanks for your help,Dave
  • Ended up using a Bissell spot cleaning machine,which we wanted to buy anyway, worked pretty well. Thanks to everyone for your help,Dave
  • Olyclean has a spray that has worked well in mine.
    Spray, let set and blot.
    Repeat as needed.
  • milo's avatar
    milo
    Depending on how big a stain ...white out works really good.
  • Oxyclean- 1 full tablespoon into a spray bottle and fill with water.
  • Use 50-50 Hydrogene Boraxide and Water, works really great. Purchase at most Pharmacy.
  • if you can deal with the over spray issue, I would hit it with Kilz primer and then the ceiling white, ore maybe consider using a roller for application. It worked in my stick home.
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
