โApr-05-2014 05:52 PM
โApr-06-2014 03:58 PM
โApr-06-2014 03:35 PM
โApr-06-2014 03:31 PM
โApr-06-2014 02:54 PM
โApr-06-2014 01:37 PM
2oldman wrote:NO! NO! NO! 36.6V*4=146.6V. Those specs are for nominal conditions. Typical variations include edge effects and temperature changes - try serial and you'll blow the controller.nvreloader wrote:Looks like that controller is good to 150vdc PV input. By far the easiest wiring is 4 panels in series with just 2 small wires to the controller.
Tristar-MPPT-60a,w/ battery temp gage will be mounted.
Is there a better/easier way, to route all these panel wires?
โApr-06-2014 10:40 AM
โApr-06-2014 09:44 AM
โApr-06-2014 09:11 AM
โApr-06-2014 08:51 AM
โApr-06-2014 07:21 AM
โApr-06-2014 07:12 AM
nvreloader wrote:The calculator is right - 4 in series would exceed the controller VOC.
Per info from the MS string calcuator for my panels,(if I entered the correct info) the panels will be 2 panels in series and 2 strings in parallel.
Tia,
Don
โApr-06-2014 12:48 AM
โApr-05-2014 07:44 PM
โApr-05-2014 06:51 PM
โApr-05-2014 06:27 PM
