Big Foot hydraulic levelers
csburks
I have a 2001 Georgie Boy Suite and one of the levelers will not retract. Is there any way to do this by hand or any suggestions?
4 REPLIES 4
Home_Skillet
Probably not the jack its self bad.
Your retract solenoid is bad.
I have jumped my solenoid to retract one of my jacks.
2005 Gulf Stream Conquest 31ft
BigFoot Levelers,TST in tire TPMS,Bilstein Shocks,Trans temp guage,Lowrace iWAY
Jaxom
rvten wrote:
Jack can be removed and sent to factory for repair. You can still use the other jacks till you get the bad one fixed.
Don't forget to plug the line where you removed the bad jack.
Jerry
2015 Jayco Seneca 36FK
2011 Jeep Wrangler Sport 2 door
2011 R & R 20' Aluminum Enclosed Car Hauler
2007 Montrose 16' Aluminum Flatbed ATV Trailer
rvten
Yes. Each Jack is independent of the others.
You can loosen the Hyd. Line. Than push the Jack up.
Use some rags as there will be oil coming out of that conn.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
1492
Moderator
Moderator
Moved from Forum Technical Support
