Black water toilet plugged
Happycamper30
Does anyone know how to unplug a toilet we use Rv'ers tissue.
22 REPLIES 22
2oldman
Don't know yet exactly where the blockage is, or whether it's a pyramid.
donn0128
Dont poo in the tank? Females need to learn to use waaayyy more water. Dry flushing is the absolute worst thing you can do. BTW the holding tank when properly used is just fine for poo also. Your going to have to spend a lot of time flushing the tank to try and disolve your pyramid of ??
westend
You probably have a pyramid of solid stuff directly under the toilet drain pipe. You will probably need to drain your tank and wash away the pyramid with a water wand and hose. Adding a bit of water softener or soap will help to move along any solids in the tank.
'03 F-250 4x4 CC
Happycamper30
Valves were closed, and I know it's just toilet paper don't **** in it, I used the end of a broom handle and probably pushed it down more
PenMan
Is it really the toilet plugged or is it the black tank? Need more info.
Chris and Jane
2013 Open Range Journeyer JT337RLS
2006 Dodge Ram 3500, 4x4, Crew Cab, DRW, 5.9 turbo diesel
1996 Harley Davidson Electraglide
rockylarson
Just to get the discussion going, have you had the black tank dump valve open while the toilet was in use. That's a no!no!. Only open the dump valves once the tanks are close to full. Take it away everyone.....
Jan and Rocky
Volunteers for USFWS. 29 refuges with 9300 hrs ea since 2006. 2004 Allegro 30DA, Workhorse 8.1, Banks, 2012 Jeep Liberty Jet, Blue Ox Aladdin, Brake Buddy Advantage Select, 300 watts solar, 5 Optima group 31 AGM's, 2000watt Ames PSW inverter.
2oldman
Lots of people know how to unplug a toilet.
donn0128
How much water do you use? We really need far more info to be of any help.
