Oct-22-2019 04:54 PM
Dec-09-2019 09:35 AM
Gjac wrote:^^Agree.
. . . there is always a middle ground . . . Life and travel all have some elements of risk and some of us are more conservative than others but there is always a middle ground.
Dec-09-2019 07:32 AM
babock wrote:If the brake fluid (along with the water, moisture, and contaminants that are emulsified within the brake fluid) doesn't cause the corrosion, then what does cause the corrosion? How do you remove it? What's the point of changing the brake fluid in the first place?
I change my brake fluid in all my vehicles every 2 or3 years. On my Lexus, I did it every 2 since the master cylinder/ABS unit was over $1000 And it was known that changing fluid increases its life.
It's cheap and easy.
Just draining the master cylinder and putting new fluid in it is kinda ridiculous. It's not the fluid that is going to be causing corrosion in your system.
Dec-08-2019 09:11 PM
Nov-13-2019 04:37 AM
DFord wrote:I think what happens is when we don't understand something completely we look for yes and no answers. Some never change fluids and never have a problem. However there is always a middle ground, where you can check your fluids. The first time I changed the brake fluid after about 30k miles and 8 years it was black and I was going to Alaska so I changed it. I felt better descending steep hills with fresh fluid. The transmission fluid at 30k miles was dark and had a lot of chips and debris in it when I drained and replaced all the fluid. Next time at 60 k there were less chips at 90k there were still some debris. If I saw no chips or debris(clutch material) I would have extended the interval. Now if I stayed on the east coast and never climbed mountains out west maybe I would not have had to change it as frequently as I did. Some people change hoses and belts every 5 years I check mine for cracks and leaks every year and have only replaced 2 belts that were cracked so for, hoses are all original. Life and travel all have some elements of risk and some of us are more conservative than others but there is always a middle ground.
It took a bit of searching but I found this on page 45 of the "2004 Scheduled Maintenance Guide" for Ford vehicles. You don't have to do anything but put gas in your RV and drive it but if you want to do the right thing, you'll change that brake fluid as recommended and every other fluid at the recommended intervals.
Nov-12-2019 11:02 AM
Nov-11-2019 10:34 AM
Nov-11-2019 04:05 AM
Nov-10-2019 06:29 PM
Nov-10-2019 05:57 PM
Nov-10-2019 05:51 PM
DrewE wrote:2009 Honda Fit manual says the same thing, except it's "information display" in place of "information". Sprinter maintenance schedule says brake fluid change every 2 years.
"Independent of the Maintenance Minder information, replace the brake fluid every 3 years."
Nov-10-2019 11:02 AM
jjrbus wrote:
So I took a look, I see no reference to brake fluid change on my 2011 Honda fit and have went over 10,000 miles before the computer told me to change oil. I am sure that if I went to the Honda dealer they would insist that they recommend changing the fluid, but would be unable to provide a technical service bulletin from Honda.
Nov-10-2019 10:10 AM
JimK-NY wrote:mapguy wrote:
My data is in the file cabinets and computers of the firms I worked at over a 35 year mechanic/Fleet Management career. Data is available from many resources besides the OEM manufacturer in all the business segments named. If hard data is what you need - where is yours to support your position. You have only attacked the real world knowledge that is trying to help educate people.
Bottom line here is safety and that is being ignored for the most part in this thread.
So according to your "data" maintenance schedules from manufacturers are insufficient both for routine service and also for safety. Let us forget the analysis. What are your recommendations for overall maintenance requirements?
Nov-10-2019 09:48 AM
Nov-10-2019 08:33 AM
Real world experience in commercial vehicles, construction equipment, powersports, motorsports and of course RV's has shown me that "Owners Manual" maintenance requirements are the minimum needed to meet Warranty requirements. ......
Again, where is the data? I also doubt that maintenance schedules are just a minimum needed for warranty purposes. Dealers want the manufacturers to provide extensive requirements.
Nov-10-2019 07:53 AM
