Braking Issues, I need help.
TeamCyBo
Hello all, i have started having brake pedal issues the last couple of times we have gone camping. First, I have a 2007 Expedition with heavy duty towing package. Our camper is a 2012 Sunnybrook 292RL. Here is what's happening. While driving through N. Ga. mountains towing our camper, I started having a problem with my brake pedal making noise and vibrating uncontrollably while braking. The situation only happens while going downhill and going into turns. My speed was about 25-35 mph. While driving and braking on a somewhat level road I had no instances at all no matter what speed or turns. This also only has occured while towing the camper so there is no problems with rotor pulsation on the Expy without the camper. When the vibration happens, I took note that there is no jerking or drag of the vehicle. I'm leaning towards some type of electrical problem. Maybe the brake controller is partly the cause. BTW, I'm an old automotive service manager and have seen most everything out there. This is unlike anything I have ever experienced. Any help on this would be greatly appreciated.
Thanks
2007 Ford Expedition, 2014 Outback 316RL Diamond Edition.
Me, My Honey Cyndie and the kids (4 Poms) Baxter, Molly, Zoe and Nikko.
19 REPLIES 19
Matt_Colie
What type (manufacturer/model) of brake controller do you have and how/where is it installed. I have seen things like this when a controller was seriously mis-adjusted and another time when the screws holding it were loose so it could shake when the retarding.
Matt
Matt & Mary Colie
A sailor, his bride and their black dogs (one dear dog is waiting for us at the bridge) going to see some dry places that have Geocaches in a coach made the year we married.
TeamCyBo
Electric only. I have played around with the settings a few times but found no change. I can dial it up and can really tell the drag on the trailer when applied also can use the manual slide to activate with no problem.
time2roll
Electric only brake controller or does it tie into the fluid?
Have you tried adjusting the brake controller gain etc?
TeamCyBo
I thought of that but it only happens when towing. I also tried somthing. I put it in low gear to slow down and it actually happened without even touching the brake pedal.
westend
Sounds like an ABS problem.
'03 F-250 4x4 CC
