โDec-28-2020 12:37 PM
โJan-02-2021 03:55 PM
dougrainer wrote:joshuajim wrote:dougrainer wrote:
Your Welcome:B Doug (NIASE certified and MASTER CERTIFIED RV TECH)
Remember, your record is good because you went for help.
PS. The MOST common cause of your problem is NOT torquing the mount bolts correctly, not that they installed the impellor wrong
Did you read the part about being an ASE mechanic. The bolts were torqued to 45 inch pounds. I still have over $10,000 worth of tools. Probably almost as many as you have. ๐
It is a good thing you fixed it. If you had taken to a Dometic service center, odds are they would have charged you for the repair. I have repaired/replaced upwards of a Thousand AC units, and NEVER had one that the Impellor was rubbing by Manufacturer (appliance)build mistake. Always install error. FYI, due to insurance purposes, My Boxes and Tools total over $34k. 41 years as an RV Mechanic kind of adds up in tools. Doug
โJan-02-2021 02:51 PM
โJan-02-2021 10:51 AM
โJan-02-2021 09:13 AM
โJan-01-2021 03:30 PM
โDec-30-2020 03:51 PM
KILL 120 power to the AC unit and recheck the fan. Doug
You did NOT buy from Dometic. You purchased from a Distributor.
No joy.
Gonna check the start cap when the wind stops blowing in the next couple of days.
Dometic recommended RV repair can look at it second week in January. Only one within 50 miles. Don't really need AC right now but heater is working properly.
Capacitor not problem. When no 120 power to the AC unit, the fan should spin freely. The Fan Motor is Bad. You have checked for binding Impellors? Who did you purchase from? Local dealer or Internet? Doug
โDec-30-2020 10:06 AM
No joy.
โDec-29-2020 03:02 PM
โDec-29-2020 02:11 PM
joshuajim wrote:wa8yxm wrote:
"It was very very stiff"
Bearings are bad
Yeah, that's pretty apparent. You would think that they would test them at the factory before shipping. Dometic got my money so why would they care if it works :S
โDec-29-2020 05:51 AM
โDec-28-2020 02:24 PM
Bearings are bad
โDec-28-2020 02:14 PM
โDec-28-2020 12:59 PM
