Dec-14-2019 09:39 AM
Sep-25-2020 03:52 PM
Dec-15-2019 12:07 PM
SDTacoMan wrote:
Hello all!
Me and my girlfriend just picked up what we thought was a nice move in ready camper, but to our dismay it had a decent leak on the front wall of the camper. We are both lacking a lot of knowledge on RV's, although I have worked a lot of maintenance jobs in the past and I'm a bit of a handyman, so we are trying to make this livable by ourselves.
After pulling the inside wall out I believe I have narrowed the leak down to the outside front corner moldings which I have removed, cleaned, and am going to apply dicor corner tape to the sheet metal and butyl-tape back on then finish it off with some pro-flex RV caulk.
While pulling the corner moldings off near the roof I found that an old coating (the previous owner claimed it was 'just' re-coated) began to peel off with the trim piece.
We were planning on coating the roof with dicor extended life 100% silicone elastomeric roof coating, but we were just going to coat on top of the old coating.
TL;DR
My question is, should I begin trying to peel the old roof coating off (as it seems to be peeling off ok here) or should I leave the coating and just apply on top of it. I don't believe I have any roof related leaks at this point of time anyways, so I'm not sure I want to go for it if it's going to cause me a ton of work.
Here are some pictures of the current roof coating:
and here is where the corner trim piece was covered by the coating, and began peeling away as a consequence of its removal:
Dec-15-2019 10:10 AM
Dec-14-2019 02:27 PM
Dec-14-2019 02:16 PM
Dec-14-2019 12:47 PM
Dec-14-2019 12:02 PM
Dec-14-2019 11:36 AM
Dec-14-2019 11:21 AM
MFL wrote:I have, but not for a complete roof job. I would not hesitate to use it for that purpose however. I would remove anything you can first.
while I have not used the Heng's rubber roof coating, I have read of many others that have, and liked it.
Dec-14-2019 11:16 AM
Dec-14-2019 11:03 AM
Dec-14-2019 10:43 AM
