Can't find my house water pump 2005 Fleetwood Expedition
Gundog
I am wanting to install a winterizing suction line with some valves. I have a bin that has most of the plumbing in it including a filter canister. I can hear the pump but I can't find it. It seems it might be behind the refrigerator. I would like to T into the line before the pump with a valve in the supply line and one on the Teed in portion for a suction line.
The current winterizing instructions call for at least 6 gallons of RV antifreeze to do the winterizing procedure. You have to use at least that much poured into the fresh water tank for the pump to pick it up. It is a pain in the butt. Has anyone had to access the water pump on an 05 Fleetwood Expedition 34H?
2005 34' Expedition Cat C7 Allison 3000
8 REPLIES 8
Reisender
There should be a little access panel in your wet bay. It’s behind there. Not sure about that specific year but that’s where Fleetwood was putting them at the time.
Grit_dog
Navigator
Navigator
Gundog wrote:
I just gave up and used 6 gallons of antifreeze.
Yuck! Why?
You didn’t put it in the FW tank I hope?
Bobbo
midnightsadie wrote:
most already have this feature built into the system.
It's not universal. My first RV had it from the factory. My current RV did not. But whether it is built in or not, he has to find the water pump because it will be located right before the water pump.
Bobbo and Lin
Gundog
I just gave up and used 6 gallons of antifreeze. If I can remember this next summer I am going to make another attempt at this project. I just need to locate the line somewhere before the pump that will allow me to access a valve I install if that is possible.
Gundog
katysdad wrote:
Did you look behind the basement panel where your city water connection is?
Yes the filter is on the back wall of that compartment and the hose runs inside the coach. I hope the water pump doesn't go out. My guess is the refrigerator has to be removed to access the pump.
midnightsadie
katysdad
Dodge Ram 3500 DRW Diesel
Bobbo
Listening for it was going to be my recommendation. Since you already did that, I have no further suggestions.
Bobbo and Lin
