Can't user 5er again this winter - replace red goo in pipes?
joebedford
Nomad II
Nomad II
For various reasons my RV won't be used again this winter. It was winterized a year ago. Does the alcohol evaporate (to where I don't know)?
Should I replace the RV antifreeze before the second winter stored outside in Canada?
30 REPLIES 30
MFL
Nomad II
Nomad II
If you used cheap AF, with the ethanol, yes the alcohol does evaporate, I would replace it. The higher quality AF, I would just leave it another year.
Also, if ethanol/alcohol version, I'd add more to the P-traps, due to evap, and possible smell from gray tank.
Jerry
