Carefree Awning Current Adjustment
hypoxia
The awning controller has an adjustment labelled "Current Adjust". Is there a published procedure to adjust the awning controller current? This is a One Touch awning but they are probably all the same.
Jim
2007 Monaco Signature Noble III ISX 600HP
5 REPLIES 5
hypoxia
Thanks, Doug
Jim
dougrainer
hypoxia wrote:
dougrainer wrote:
WHY do you need to do that? Doug
The awning is sluggish & moves very slowly. If there's a 15 knot breeze it needs help, someone pushing on the arms. I wash the straps and am liberal with silicone on the straps which helps quite a bit but doesn't cure it. It is a 13 year old One Touch patio awning.
One Touch Awning
The current adjustment is for the In and OUT stops. From your complaint, your motor is bad. The current adjustment does not fix this type problem. Doug
hypoxia
One Touch Awning
Jim
dougrainer
SoundGuy
If this isn't sufficiently covered in your Carefree owner's manual I'd call the company and ask them.
2012 Silverado 1500 Crew Cab
