Carry out satellite dish for DISH 722K receiver
Homeless_by_Cho
I am looking for recommendations for a carry out portable satellite dish for DISH TV 722K receiver. I have looked at several manufacturer websites but none list the 722K as compatible. My friend who has a Direct TV was told that a certain brand carryout works for Direct even tho the manufacturer says it is not compatible. However, it works just fine for his Direct TV receiver.
I was wondering if any of you have experience with a portable dish for the 722K receiver.
Thanks,
LeRoy
Homeless by Choice
FULL TIMER since 2012
2015 Chevy 3500, Duramax, 4X4, DRW, Crew cab, Long bed
2013 Northern Lite 8'11"Q Sportsman truck camper
2015 Polaris RZR Side by Side
11 REPLIES 11
SaltiDawg
Dutch_12078 wrote:
Also note that the G2+ only receives the Dish western arc satellites, limiting the options around trees and other obstructions, as well as limiting the availability of the local channels in some areas.
If the antenna can only receive one sat at a time, why can't it be pointed at Eastern Arc Sats - or indeed any single sat?
No argument, just curious.
Dutch_12078
Dutch
2001 GBM Landau 34' Class A
TechWriter
Homeless by Choice wrote:
Winegard returned my phone call and said that the ONLY Winegard product that would work with my 722K receiver is G2+ Carryout. I have to put a "power inserter" which comes with their system in the coax line, supply 120vac to it until it finds the satellite (and then I can unplug it) and the 722K should receive all my DISH HD channels.
Kind of.
From the G2+ Manual . . .
Q.
Does the Carryout G2+ antenna work with a DVR?
A:
Yes, the Carryout G2+ antenna can be set up to work with most DVR receivers. Two coaxial cables will need to run from the Carryout G2+ antenna to the DVR, and the receiver will only be able to watch or record from one satellite at a time, which may limit some DVR functionality. The Carryout G2+ antenna is not compatible with the Hopper/Joey for DISH. The Carryout G2+ antenna is not compatible with H25, HR34, or HR44 for DIRECTV (unless the SWM-840 accessory kit is added).
www.rvSeniorMoments.com
DISH TV for RVs
SaltiDawg
I've had a Dish 722k for many years. It, of course, can record four channels simultaneously (Two OTA and two from a Sat) while simultaneously viewing a previous recording.
I'm not an RVer, but to get all available HD recordings I have to look at THREE satellites. That includes my "Local" Channels.
Homeless_by_Cho
Carryout G2+ Features
Compatible with multiple providers
Easily switch providers at power inserter
Powered over coax through power inserter
Permanent & temporary mount options
Fully automatic satellite acquisition
Simple setup
Multi-TV viewing
Ultra-small and compact
from Clicky
LeRoy
Homeless by Choice
lryrob9301
Try DISH OUTDOORS 1-800-970-9021. They will sell you everything you need.
Homeless_by_Cho
Goostoff wrote:
Is there any special reason why you insist on the 722? We just added the tailgater to out bill for $7 a month
I have the 722K for many years and now that I travel, I take it along with me; no loyalty to the 722 just existing receiver.
I see on the internet the $7 offer but I can't find out any information on what receiver is required. Could you direct me to a website or phone number to get this information?
Thank you,
LeRoy
Homeless by Choice
Goostoff
1993 Chevy C3500
2005 Cedar Creek 34RLTS
Rjdreyer
Here is a link that might assist
http://www.tv4rv.com/sunshop/
Homeless_by_Cho
brirene wrote:
I'm using the Winegard Anser with my 625dvr. It indicates it's compatible with all dish receivers except the hopper/joey. I've had good results with it.
I just went to the Winegard site, entered my information and got the following message
Search Results
Selected Features: Portable | Automatic | Stationary | Dish Network (High Definition) | Multiple TVs
Please call Winegard Company Technical Services at 1-800-788-4417. Your area has special circumstances that require additional information.
I called and found that Winegard tech support will open at 7:30 AM CDT. I will try again in the morning.
Thanks,
LeRoy
Homeless by Choice
brirene
Jayco Designer 30 RKS Medallion pkg, Trail Air pin
'05 F350 6.0 PSD CC 4x4 DRW LB B&W Companion, Edge Insight
โ€œCertainly, travel is more than the seeing of sights; it is a change that goes on, deep and permanent, in the ideas of living." Miriam Beard
