Jul-04-2019 07:05 AM
Jul-04-2019 08:42 PM
pinesman wrote:
I got to thinking about using those same cables to charge my batteries using the truck. I would not be using it for hours to run everything but just a little while to top off the batteries in the trailer.
theoldwizard1 wrote:
Modern vehicle (after about 2000) charging system work TOTALLY DIFFERENT than the past. They drop the voltage down to about 13.2V within a few minutes of starting. That is much TOO LOW to charge such a large battery bank !
Jul-04-2019 05:13 PM
Jul-04-2019 05:09 PM
theoldwizard1 wrote:landyacht318 wrote:
I found maxing out my alternator charging well depleted battery over thick copper when idling parked had my alternator quickly heat to 200 f+ degrees. But I can force.it.to seek and hold 14.7v.
What year, make and model vehicle and how do you force the alternator to seek and hold 14.7V ?
Jul-04-2019 04:47 PM
RoyB wrote:
Mine has these 2-pin connectors on it and I built up a lighter plug adapter so I can plug this solar panel into an always hot 12V Connector inside my truck... Great for trickle charging my truck start battery doing this...
Jul-04-2019 02:18 PM
Jul-04-2019 02:14 PM
Jul-04-2019 02:11 PM
Jul-04-2019 01:22 PM
Jul-04-2019 11:33 AM
Jul-04-2019 11:02 AM
Jul-04-2019 09:57 AM
Jul-04-2019 09:11 AM
2oldman wrote:
Solar is a better solution.
Jul-04-2019 08:55 AM
Jul-04-2019 08:14 AM
Jul-04-2019 07:52 AM
