โMay-29-2013 08:16 AM
โJun-07-2013 11:28 PM
HiTech wrote:
You can roll up a Unisolar into a similar packed-up volume and do the same kind of thing for less money and more watts. That's how they ship them.
Jim
โJun-07-2013 09:48 PM
โJun-07-2013 08:11 PM
โJun-07-2013 03:17 PM
pnichols wrote:crcr wrote:
I seen those EX650 gens come up on ebay from time to time. Do you know what year they quit producing them? What do they weigh? What is it, 650 watts output? Thanks.
You probably missed my 2nd post earlier where I provided a link to a chart comparing the specifications on a lot of the older small Honda constant speed generators. As you've found out, many of these good old 3600 RPM Hondas can be had for a song with plenty of good camping years still left in them.
Here's the link again:
http://www.tappedin.com/hop/html/litegen.htm
I'm not sure when they stopped producing the EX650 - around the late 1990's, or 2000, I think. I also was recently given a Honda EX1000 in like new condition and I'll use it outside around our residence instead of in the RV because of it's 64 dB noise level - too high for battery charging when camping. I'll keep the little EX650 (it's at least 25 years old) in the RV for it's ultra-quiet sound level of 54dB.
I have nothing against solar, but I think it should only be part of the total power mix for a well-equipped self-contained RV. Here's what I think are two very flexible setups for RV power generation in all conditions (in addition to a large battery bank and an inverter or two):
A) The next best setup - portable solar panels (not on the roof), small quiet generator for battery charging when the sun can't do it, large quiet-as-you-can-afford generator for hot weather/high humidity air conditioning.
B) The best setup - portable solar panels (not on the roof), fuel cells for battery charging when the sun can't do it, large quiet-as-you-can-afford generator for hot weather/high humidity air conditioning.
The reason I'm a fan of portable solar panels is that you can move them into the sun if you're fortunate enough to be able to park the RV in the shade and/or if you're paranoid (like me) about not having any more holes in the roof than what you already have. I also don't care for how roof mounted solar panels restrict access on the roof ... I want to be able to crawl all around up there to wax it, make modifications, and repair/inspect stuff.
โJun-07-2013 07:55 AM
โJun-07-2013 12:38 AM
โJun-06-2013 10:21 PM
โJun-06-2013 04:50 PM
smkettner wrote:X2!!
I can't wait to see a pic of that solar scooter :B
Club car will be next year ๐
โJun-06-2013 03:27 PM
โJun-06-2013 03:04 PM
pnichols wrote:
The Honda EU2000i runs at a 53dB sound level when delivering about 400 watts (1/4 of it's 1600 watt continuous rating).
My Honda EX650 runs at a 54dB sound level when delivering 550 watts (all of it's 550 watts continuous rating).
Since my RV's battery bank usually charges initially at no higher than around 30-35 amps anyway, I'll probably stick with our little EX650 as long as I can keep it running. Our EX650 is around 25 years old and still starts right up even after leaving it setting around with ethanol blend gas left in it's tank, fuel line, and carburetor. It's engine is four-cycle, so no mixing.
I know most folks seem to love to buy brand new, but FWIW, one can still find the Honda EX650 used in the $200-$300 range.
โJun-06-2013 02:42 PM
โJun-06-2013 02:38 PM
โJun-06-2013 02:00 PM
โJun-06-2013 12:56 PM
โJun-06-2013 12:28 PM
