May-09-2021 02:29 PM
May-10-2021 05:23 AM
May-09-2021 09:56 PM
ksg5000 wrote:
When on "auto" the fridge should resort to AC if it's available. If no AC then it will revert to gas and the Check Light will come on if the gas fails to ignite. If you select "gas" and your haven't turned on the propane and you don't get a "check light" then something maybe wrong - light bulb or maybe bad board.
If it were me I would turn on the gas - select gas and then see what happens. Make sure the gas lines are purged - (turn on the gas stove). If that works then I would plug in the RV to AC and select auto - and see what happens.
May-09-2021 09:31 PM
bgum wrote:yes
What? Is both auto and gas lit?
May-09-2021 03:25 PM
May-09-2021 03:04 PM
