circuit breaker location
Jim_S_
I have a 2005 Sunnybrook model 2706. It has circuit breakers located in 3 places, above the sofa, in the breaker box and a third location that i cannot find. I know there is a third location because i had to take it to a dealer once before after the campground took a lightning strike. The dealer fixed it but did not tell me where it was located. Anyone have any thoughts???
1 REPLY 1
wa8yxm
Do you have an inverter? If so it may have breakers mounted on it,, often on the side you can not see (of course) use an inspection mirror.
Also there may be some 12 volt breakers.. My Gasser has an Inetlletec Battery Control Center... Diagerams downloaded from the manufacturer of said device show a pair of POST type (PUSH HARD TO RESET) Breakers,, I do not have them but the diagram shows them (I have a self-resetting breaker nearby.)
