If it is the starter relay (actually the run relay) there will be no voltage on the compressor leads.
Most any relay capable of operating a motor at 20 amps 120 volts will work. it may not fit on the board (you may need to "Remote" it with jumper leads.
But any relay designed to run a 2 HP motor should work.
Might be able to use a smaller one (I tend to use components on the "Heavy duty" side of life to avoid overload)
