COMBUSTION SMELL FRO HOT WATER TANK
bullyus
The hot water tank will really smell of combustion at times. If the door to the trailer is open it will even come in the trailer. Also the outer cover seems to be hotter than usual.This seems to be a new issue. Noticed it once last year and twice this year. The flame is a very nice blue and nothing appears to be plugged. It allways lights and is very quiet. Any Ideas?........... Bullyus
2003 KOMFORT 25TQSG TRAILER
2000 GMC 2500 6.0 liter 4:10 axles
PRODIGY
1 WIFE
1 SMALL DOG
7 REPLIES 7
j-d
Gjac wrote:
If you have never cleaned the flue I would do that first.
By ALL means!
Gjac
Delete Dup post
Gjac
If you have never cleaned the flue I would do that first. You will have to remove the burner tube and the exit vents to run a bottle brush or a coat hanger and rag through the flue. Spiders and other bugs can build nests in there and that can burn causing the smell. I blow mine out every year in the spring with compressed air and always see debris that comes out. As others have said it could be incomplete combustion and if you play withe the slider that adjusts the air to propane until you hear a slight roaring sound and all the yellow goes out of the flame, that may help also.
DrewE
It sure sounds to me like something in the burner assembly or flue needs adjusting or cleaning. Even though the flame looks OK, I'd give it a decent going over.
(Running on electric isn't at all a viable option for a good many RVers who, like me, have gas only water heaters!)
1492
Moderator
Moderator
Moved from Forum Technical Support
rockhillmanor
My hot water heater is right outside my kitchen sink where there is a window. If I have the window open and turn the hot water heater on the exhaust smell comes right in. I now make sure that window is closed when I turn the hot water heater on. And yes I only turn it on when I need it.
The wind does also have an affect on how much comes in too. Could be why you sometimes smell and sometimes not.
stickdog
Try it on electric no fumes.
9-11 WE WILL NEVER FORGET!
FULLTIME SINCE 2010
17 DRV MS 36rssb3
17 F350 King Ranch CC DRW 4x4 6.7 4:10 B&W hitch
John
โ€œA good traveler has no fixed plans, and is not intent on arriving.โ€ Lao Tzu
