โDec-18-2017 12:47 PM
โDec-18-2017 02:30 PM
PaulJ2 wrote:
I have a Phillips Respironics unit myself. My TT has a 12 volt socket and i just plug into that with the optional 12 volt cord i received with the unit.
You might check into that option.
โDec-18-2017 02:28 PM
beemerphile1 wrote:
Respironics operate on 12vdc and can run directly from a battery with the correct cord. Check your specific model for clarification by looking at the label on the unit.
Are you looking to use this in an RV? Most all RVs already have a 12vdc system you can simply plug into.
FWIW, Resmed units operate on 24vdc and have a converter cord to plug into 12vdc.
The respironics cord is around $25 and the Resmed cord is around $80.
โDec-18-2017 02:26 PM
โDec-18-2017 02:25 PM
beemerphile1 wrote:mileena wrote:
...It is a Philips Respironics DreamStation. I will go to their site and buy a battery....
If you truly need a separate battery, do not buy the CPAP $400 battery pack. Any AGM battery for $100 will do just as well if not better.
โDec-18-2017 02:22 PM
โDec-18-2017 02:15 PM
โDec-18-2017 02:02 PM
โDec-18-2017 02:01 PM
โDec-18-2017 01:55 PM
โDec-18-2017 01:39 PM
gkainz wrote:
First, please edit your photo sizes - my 2 monitors just about display your pics! ๐
gkainz wrote:
Second, That's the least efficient way to connect your CPAP to a battery. To go from DC to AC and back to DC again - (assuming your CPAP, like nearly all I've had or are familiar with - has the AC to DC brick in the power supply cord, and run off of 12VDC) induces a lot of loss.
CPAP supply companies have portable batteries available specifically for their matching machines, and of course, you pay 2-10x premium for the "name brand" matching.
My most recent CPAP (ResMed) runs off of 24VDC so I'll end up buying the 12 to 24V DC step up transformer and run off a jump start battery pack.
My prior CPAP all used 12VDC, so I made a 12V adapter to plug into a jump start battery pack similar to what you show, but mine had the cigarette lighter socket built into it.
So, a little research on your specific CPAP to see what the input voltage requirements are and you "should" be good without the converter.
Good luck!
โDec-18-2017 12:59 PM
โDec-18-2017 12:52 PM
