โOct-21-2012 03:43 PM
โNov-04-2013 02:56 PM
โNov-04-2013 02:05 PM
โNov-03-2013 01:10 PM
โNov-03-2013 12:56 PM
pnichols wrote:The Powermax Boondocker series do. They're deckmount converters not the drop in replacements though.
Note that Powermax converter/chargers do not have PFC (power factor correction) circuitry.
โNov-03-2013 12:17 PM
โNov-03-2013 10:59 AM
pkunk wrote:BFL has one and he and smk recommend them quite often.
I don't understand why no one has recommended the Powermax Boondocker converter charger. They readily go into boost, are a 4 stage charger, and the 35 amp would likely run on the 1000w genset
โNov-02-2013 08:02 PM
โNov-02-2013 12:52 PM
โOct-24-2013 07:29 AM
MrWizard wrote:
i don't understand why people can't do a no load 2 minute warm up ECON off,
plug in the load, then switch Econ on
its lot easier on the genset, there is little noise in a NO LOAD warm up,
and the genset takes the load so much easier with econ OFF, then throttle down to econ mode
โOct-23-2013 10:27 PM
โOct-23-2013 10:11 PM
โOct-23-2013 09:52 PM
โOct-23-2013 09:31 PM
โOct-23-2013 09:06 PM
RJsfishin wrote:BFL13 wrote:
RJ it turns on my definition of "forever" I did not say a 45a charger would not run on the 1000w Honda. The OP had a 55a.
How long forever lasts depends on how big the bank is in AH and how low it starts at on the recharge and how high you want to get it to.
My PD 45 will charge faster than the OPs 55 amp WFCO that never sees 14 volts. So I didn't know why you would say that.
I used to charge w/ a PD55 amp, and I don't notice the difference.
But, at any rate, the Honda 1000 will charge batteries plenty fast on 45 amps. The 1000 is smaller and lighter, and quieter once the amperage get down to 30 amps and less.
