Crispy brown 921 socket?
Mafman
Anyone else have an issue with 921 bulbs cooking the sockets? Ours
Are turning brown and becoming worrysome. I know switching to LED will address the issue but was wondering if this is a common thing in the meantime.
2013 Avenger 28BHS
2009 Puma 19FS
2012 GMC 2500 6.0L- 3:73
2009 GMC Sierra 5.3L - 3:42
EAZ Lift - proStar Ultra
DW, 2 DKs
6 REPLIES 6
hotpepperkid
My porch light did that. Had to replace the complete fixture as the bulb welded itself in the socket
2019 Ford F-350 long bed SRW 4X4 6.4 PSD Grand Designs Reflection 295RL 5th wheel
KJINTF
YES!!
Have seen that many times
Once or twice it burned the switch assembly
My customer asked how could this happen .... Well poor connections and high current -- the result is always bad or really bad
Get rid of the 921 bulbs and get some LED's in there before you have a fire
tvman44
Yep, common problem, replaced all of mine with the 48 LED boards from china, a lot less power consumption and heat and better light. ๐Ÿ™‚
Papa Bob
1* 2008 Brookside by Sunnybrook 32'
1* 2002 F250 Super Duty 7.3L PSD
Husky 16K hitch, Tekonsha P3,
Firestone Ride Rite Air Springs, Trailair Equa-Flex, Champion C46540
"A bad day camping is better than a good day at work!"
RoyB
Certainly happened in my POPUP trailer. The socket area, the lens, and even on the ceiling was being affected by the hot incandescent 921 bulb. Changing to the $4.95 ebay/china board was a no-brainer for me...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
jhilley
Maybe the socket is only rated for a 912 lamp. The 912 is 1 amp and the 921 is 1.4 amps at 12.8 volts. An LED lamp is the best solution.
2003 Winnebago Adventurer 38G F53 Chassis Solar Power
1999 Winnebago Brave 35C F53 Chassis Solar power
Handicap Equipped with Lift & Hospital Bed
1999 Jeep Cherokee Sport
1991 Jeep Wrangler Renegade
stevejberry
can you post a picture of the cooked socket. i'm curious
