wopachop
Aug 23, 2020Explorer
There is also a start toggle on the genny itself. You can use that and cross your fingers if it happens again while camping.
Could be a bad switch inside the trailer. Loose wires to that switch. Loose connection on back of switch.
Remove that panel and check out the work. I have a stealth and constantly amazed at how bad the construction is. The wiring is really bad on my particular 2013. Hopefully that crew is gone by the time they made yours!!!
Having RV issues? Connect with others who have been in your shoes.24,208 PostsLatest Activity: Feb 27, 2025
