โApr-05-2016 04:09 PM
โApr-07-2016 06:18 AM
โApr-07-2016 05:06 AM
westend wrote:marty1300 wrote:
OP here- thank you for the assistance and help its all figured out and we have power to the AC inverter
There, fixted it for you.:B
โApr-06-2016 06:09 PM
โApr-06-2016 05:22 PM
MrWizard wrote:
Inverter versus converter
They are Two Different things
Unless you purchased a combo inverter/charger unit
Inverters take DC power and make AC power to run things like the TV and DVD player satellite box etc
Converter charges your battery
โApr-06-2016 04:44 PM
โApr-06-2016 03:26 PM
โApr-06-2016 11:08 AM
pianotuna wrote:To be more specific if you refer to the nice picture that Roy posted for the 6v battery set up, you would connect your pos wire from your inverter to the +12v wire on your first 6v battery and your neg wire on your inverter to the wire marked ground on the second battery in his picture.
Use the positive from one six volt and the negative from the other six volt.
โApr-06-2016 05:08 AM
โApr-05-2016 08:24 PM
marty1300 wrote:
When I put a wire on 1 neg. And 1 pos. ( 1 from each battery ) I only measured 6 volts, that is why I was inquiring I thought I would 12 volts
โApr-05-2016 07:42 PM
โApr-05-2016 07:34 PM
โApr-05-2016 05:12 PM
โApr-05-2016 04:30 PM
โApr-05-2016 04:26 PM
marty1300 wrote:There's only one way.
What would be the best way.
