Dead House Batteries
rmchipmanhughes
First Time Posting:
RV has been plugged in to house power for several weeks.
Inverter shut down (blinking red) due to low voltage in house batteries.
Now ac will not run even with shore power still hooked up.
I appreciate your help!
Thank you,
Marilyn of Arizona
21 REPLIES 21
MrWizard
Moderator
Moderator
well, the crystal ball broke many years ago, and chineese replacements don't work for my purposes, and i have been unable to get back to Hogwarts
I can explain it to you.
1997 F53 Bounder 36s
pianotuna
Nomad III
Nomad III
And you call yourself a Wizard.......? *huge grin*
Regards, Don
2edgesword
Welcome to the forum.
If the RV is plugged into shore power and is actually getting shore power (circuit breaker didn't trip and you're actually not getting power to the RV) then there is probably an issue with the converter. The CONverter (different than an INverter) is going to distribute the A/C electricity as well as convert A/C to D/C for charging the batteries and powering other D/C powered items (lights, thermostat, refrigerator controls, etc.).
As mentioned the first thing to check is that you are actually getting shore power into the RV. If you are then check the converter D/C output voltage using that voltmeter you mentioned across the wires connected to the battery terminals. It should be ~13.6V. Since the batteries are dead it's likely you're not getting proper charging voltage but it should be checked anyway just to insure whether the converter is the problem or not.
MrWizard
Moderator
Moderator
We do not have magical crystal balls
We need all the pertinent information you can supply
Electrical can be complicated or simple
rmchipmanhughes
Thank you pianotuna, I will check it out...thank you for your advice.
Marilyn of AZ
pianotuna
Nomad III
Nomad III
Hi Marilyn,
Welcome to the forums.
The roof air may require a good 12 volt source for the control boards.
Start by checking the shore power. Make sure there is power.
If there is, then check the output of what ever device charges the battery bank.
rmchipmanhughes.net wrote:
Thank you gatorcg for your reply...
2005 Coachmen Cross Country Diesel Pusher
The Inverter model is a Tripp Lite 612
It has 6 (six volt) house batteries wired in series/parallel
My husband is a DIY'er but has limited electrical experience but can use voltmeter and test light.
Marilyn of AZ
Regards, Don
rmchipmanhughes
Marilyn of AZ
rmchipmanhughes
Thank you Mike, I am sending you a Quick Reply to thank you for your help and the link for help.
Marilyn of AZ
rmchipmanhughes
I think I have it now, I am supposed to post a reply. Not enter a question at the bottom of the page and post it.
I hope this is right as I am getting kind of frustrated. Just trying to repair my old class a rv and get back on the road again.
You can respond by filling in the box at the bottom of the page ("Quick Reply"). Sometimes it's better to click the "quote" on the upper right of what you're responding to, which automatically shows their post, then you can add your reply below it.
If you want more help on how to work this board, this is the place to ask.
rmchipmanhughes
Marilyn of AZ
mike-s
rmchipmanhughes
Marilyn of AZ
gatorcq
First why not post what make - model of inverter/charger you have.
If you tell me you don't know, then please start looking for it.
Some people like to know the make and model of the Rv you have also.
Example, my MH has a Xantrex Inverter AND charger combination unit. I also have a inline fuse to the inverter/charger batteries.
I need to plug in or run the generator for it to operate.
It can run on generator but not work on shore power due to a bad automatic transfer switch (ATS).
Now I can go on. but please think about this, for me, I need additional information to help. Others may chime in, but I do believe we all need additional info.
And finally, are you a DIY'er, able to use a voltmeter and limited tools? If not, then you really need to call someone who can, to help you.
Dale & Susan
DaGirls II Rv - Dakota & Tilly Traveling Companions.
2008 Alfa Gold, 2015 Ford F150 XLT
Roadmaster and Air Brake System
1600 Watts, Magnum Inv/Chg&Solar
800 Lithium Battery
DaGirslRV Blog
rmchipmanhughes
Thank you Mike, I will check the circuit breakers.
Marilyn of AZ
