Delamination remediation
darsben1
I have a small area of delamination just below the RV refrigerator outside access panel.
If I remove the panel completely I would have room to put something in there to reglue the area. spraying would be easiest for me but I want effective. The area extends downward abut 30 inches and side to side about 24 inches.
I am looking for a relatively simple fix that I can do myself.
What are your thoughts?
I am looking for first/second hand experiences. I know how to search and look at YouTube videos on my own.
Traveling with my best friend, my wife in a 1990 Southwind
19 REPLIES 19
darsben1
The leak will be stopped when I reinstall the vent
KMLsquared
Don't mean to hyjack but what if the leak was cured. Is there any harm in not fixing the delam issue?
2002 Doge RAM LB QC 4x4 HO 6spd
2003 Rampage 33TB
2007 CRF80F
2006 TTR50E
2004 CRF70
2002 TTR125L
2002 Banshee
1969 Baja Bug
Joe417
I have only done re-lamination by peeling the skin back and drying everything.
There is a video on youtube showing how to inject the glue under the skin. A little simpler for you since it's directly under the fridge vent.
For injecting, I'd suggest liquid polyurethane like Gorilla Glue. If it is still damp the Gorilla Glue reacts faster with moisture. Cures in an hour or so but I'd leave it clamped up for a couple of hours.
You'll need to use a sheet of plywood or particle board as a pressure pad over the de-laminated area as the glue will expand while curing. I've heard several on rv.net say they held the pressure on it by parking close to a building as Kayteg1 said.
I used 2x4s and built a frame around the camper to push against. Then clamped the pressure pad in place using Erwin hand clamps.
Good luck.
P.S. hope you got the leak stopped or it will happen again.
Joe and Evelyn
darsben1
Keyteg1
How long ago did you do this? I am thinking about the longevity of the repair
Kayteg1
In my case I had the outside skin coming off in panels, what made the job easier.
After cleaning all rotten/loose stuff I used This glue
Holding the skin during process is the trickiest part as the glue needs couple of days.
I had camper between house and masonry fence, so after finding wide planks or plywood, I put sticks giving it some pressure.
For narrow areas that need glue - I used paint mixing sticks that you can get for free at HD.
