โAug-07-2023 06:48 AM
โAug-08-2023 04:17 PM
dougrainer wrote:
IF you have the tstat I posted link too. IF you have Fan speed set to Hi or Lo, then IF you have 120 available the roof AC fan will come on. to STOP that you set the Fan speed to AUTO and when on furnace the roof AC fan will NOT run. Doug
โAug-07-2023 02:34 PM
โAug-07-2023 02:20 PM
โAug-07-2023 10:05 AM
โAug-07-2023 09:37 AM
โAug-07-2023 09:28 AM
DustyRooster wrote:
Hi Doug
Thanks for the reply. I will give the "auto" fan a try, it was set on high.
I DO have 120ac available Via Inverter, but turn off the inverter at night due to the inherent battery draw of the inverter, so the furnace ALWAYS sees 120ac if I have the inverter ON.
I don't want the HP kicking on when it sees 120ac coming from the inverter, and its not as simple as shutting off the AC breaker.
Your observation is correct about my lack of knowledge on the system. I am on my first shakeout after purchasing THIS particular Rig, looking for some help.
I came from rigs without heat pumps. Furnaces ran just fine on DC alone and was in no way connected to the unit on the roof. I just want to break any heating connection from the heat pump on the roof and the propane furnace, right now, the 2 ACT like they are DEPENDANT on each other.
The Serial # on the stat is 3313195.012, which does NOT have the option for a HEATSTRIP or HEATPUMP like the 3313194015's.
So it looks like the rig I bought had the AC replaced with the heatpump option, but they never installed the new thermostat to control the heat pump option but who knows, my knowledge is limited about this system.
This could be as simple as using the correct thermostat for the options installed....which what was recommended.
Thanks for your time, Doug. I do appreciate it
โAug-07-2023 09:13 AM
โAug-07-2023 08:14 AM
โAug-07-2023 08:05 AM
โAug-07-2023 07:59 AM
โAug-07-2023 07:25 AM
โAug-07-2023 07:04 AM
