โJun-25-2013 06:03 PM
โJun-28-2013 10:09 AM
โJun-28-2013 10:07 AM
โJun-28-2013 10:01 AM
full_mosey wrote:full_mosey wrote:full_mosey wrote:
I remeasured today @ Noon.
Optimas = 108F
MS SS10 = 116F, jumpered at 14.4V
Turnigy Volts = 13.85, result of 116F ambient temp comp by SS-10
I will hook up the Turnigy to get the charging Amps and post around 3PM today.
I still maintain that I have never observed any out-gassing from either the Deka or the AGMs. If my AGMs are damaged, won't that be apparent when I run capacity tests next month?
HTH;
John
2PM;
Deployed the Turnigy. There was .30A and 7.75Ap reading. The 0.30A decreased to 0.00A within one minute. That's no, zero, nada mA.
3PM:
One hour readings:
Optimas = 110F
SS10 = 119F
Turnigy = 0.00A, 13.80V, 0.011Ah, 7.75Ap, 0.1Wh
I don't see any danger of outgassing with these readings as there is virtually no power.
For skits and grins, I changed the SS-10 jumper down to 14.1V which resulted in 13.50V, down from 13.80.
HTH;
John
It is now 8:53PM. sunset was 8:47PM. Let's call that 6hrs past 3PM.
Optimas 106F
SS-10 109F
Turnigy 0.00A 13.29V 0.011Ah 7.75Ap 0.1Wh
โJun-28-2013 05:33 AM
โJun-28-2013 03:09 AM
โJun-28-2013 12:08 AM
โJun-27-2013 09:13 PM
full_mosey wrote:IMO, that 15.6V is the only way I can think of to blast lots of amps into a battery quickly. But I am far from an expert on this. Also, I thought MEX had mentioned that really low amps with "high" volts had no ill effects on a battery. Hopefully, he'll correct me if I misunderstood him.
And yes, Optima is very aggressive with their charging specs. The rapid charge spec of 15.6V with UNLIMITED Amps seems to cause the most heartburn around here with the FLA folks. I don't have any problem with that spec at all.
โJun-27-2013 07:13 PM
Optimas = 108F
HTH;
John
2PM;
3PM:
One hour readings:
Optimas = 110F
SS10 = 119F
HTH;
John
โJun-27-2013 02:49 PM
โJun-27-2013 02:21 PM
HiTech wrote:
I never know how to map the daily solar cycle into float specs properly.
Jim
โJun-27-2013 02:11 PM
โJun-27-2013 01:45 PM
Optimas = 108F
HTH;
John
โJun-27-2013 12:17 PM
