โNov-18-2018 11:56 AM
โJan-19-2019 10:24 PM
โNov-28-2018 04:47 PM
dougrainer wrote:motc777 wrote:jkwilson wrote:motc777 wrote:
This thing ran all night long and all day long on electric. I just got home and while still cold I noticed that the pipe on the outside cover is not as hot as it was. Itโs lukewarm and the coils on the back of fridge are cold. The frost on the fins has gone away too. Itโs like itโs not working again.
I read that if it work son propane but not on electricity then likely itโs the element. But I literally just replaced that a few days ago. Did I get a bad element? Is there some other problem?
Turning the heat on and off is how the refrigerator controls the temperature, so if the refrigerator thinks it is cold the element may not be hot.
An easy check is to make a short cord with blade terminals on the end to apply power directly to the element. The unit will run wide open and probably ice up. If it gets really cold after a day running like that, the element and cooling unit are fine.
OK, not to be thick, but just double confirming. So when running on AC, it is normal for the heating element to cool down and warm up depending on if the fridge thinks it cold or hot?
I have a new thermistor that I haven't installed yet. Should I just go ahead and do that? Mind you, prior to all this ****, both the freezer and the fridge would ice up bad, but since replacing the heating element, hasn't happened at all.
The Thermister sends a signal to the control board when the set cold temp has been reached. The board turns off the 120 element. It also turns off the LP if on LP. When the fins start to warm up, the Thermister sends that signal to the board and the board starts the appropriate Heat source(120 or LP). A BAD Thermister will test(OHM out) correctly, so replacing is the only sure way of knowing. BUT, the standard practice for professional Technicians is to wire the 120 element DIRECT to 120 for 24 or 48 hours to get the lowest possible temp. I use a Temp LOGGER that I place in the refer. It takes temp measurements every 15 minutes. I then download the LOG and print out the graph for my use and to show the customer. VERY accurate and VERY good tool to verify operation of a Refer or AC system. Doug
PS, AS I stated earlier, you need an AMP reading multiplied by the actual LINE voltage to get the wattage. Most 120 elements are in the 325 watt range, but the spec sticker on the refer will state the Wattage required. LOW AC voltage will affect the operation on 120. Anything below 115 volts will have an adverse affect. WHAT is the line voltage at the refer?
โNov-28-2018 04:40 PM
โNov-28-2018 04:30 PM
โNov-28-2018 04:17 PM
โNov-28-2018 03:29 PM
โNov-28-2018 04:33 AM
โNov-28-2018 04:08 AM
motc777 wrote:
Update:
It's now 10:28PM CST. It's been running on electricity since about 4:30-5pm today. I just checked freezer. For the first time since this whole episode started, I have a cold freezer. I just moved the thermostat inside the fridge portion down about 1 hour ago to about midway, and the fridge is cold! There is even a bit of frost formed on the fins!
I'm letting it run all night, but if this works, I really would like to know why, when I replaced the element the first time, none of this was working properly? Could just simply cleaning off some electrical terminals on the back panel have done it?
โNov-28-2018 02:37 AM
motc777 wrote:
Update:
โNov-27-2018 07:31 PM
โNov-27-2018 02:39 PM
โNov-27-2018 08:50 AM
โNov-27-2018 08:30 AM
jkwilson wrote:
Any chance you got the wrong element? I believe yours should measure 44ohms.
โNov-27-2018 08:27 AM
dougrainer wrote:
NEVER a control board. All they do is switch between LP and 120 and monitor the cold for the Thermister.
ARE you POSITIVE you put the correct wattage Heat Element in? They are not all the same. In extreme rare cases the heat element tube is not attached securely to the burner flue. NO problem on a Dometic as Dometic has 2 heat element sleeves. If you suspect this you just move the heat element to the other sleeve. To verify the Heat Element wattage you either look at its stamped display on the element or you do a AMP check. The amp check will tell you the wattage. Doug
