Dometic toilet floor seal
keyspirate
Has anyone ever replaced the foam floor flange seal with a wax ring? If so how did it work?
5 REPLIES 5
drsteve
3 tons wrote:
....IF you have a sani-flush with an interior located anti-siphon VENT valve - trust that this can be very bad news...
Many people get rid of the interior vacuum breaker and instead use one on the threaded connector outside...
2006 Silverado 1500HD Crew Cab 2WD 6.0L 3.73 8600 GVWR
2018 Coachmen Catalina Legacy Edition 223RBS
1991 Palomino Filly PUP
RJsfishin
When I replaced the broken holding tank, the toilet had a wax ring that showed no sign of ever leaking, so when I reinstalled it on the new tank, I used a wax ring. (5 yrs ago)
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
3_tons
After lots of nusance odors, and after changing out the foam seal, 4 yrs back I finally adapted a wax ring to remedy this dreaded problem and have been very pleased ever since - no vibration issues to date...Disposable gloves work wonders, and Iโ€™m a fairly well rounded DIYโ€™er, so am greatful I can handle my own repairs...Another thing to be aware of is IF you have a sani-flush with an interior located anti-siphon VENT valve - trust that this can be very bad news...
dougrainer
Why would you want to do that????? A Foam seal has been used on MILLIONS of RV's over the years and have np problems on install. Less mess than a wax seal. The only thing, is, you may have to replace the Foam seal after 10 years or so from it drying up and shrinking. Yes, I have had customers do that and they paid extra for me to fix the problem because cleaning up that wax seal mess is a pain. Doug
Dutch_12078
Wax rings are not recommended. The normal RV vibrations while in motion can displace the wax enough to cause a leak. The correct foam gaskets are readily available and inexpensive. I would only use a wax ring as a temporary fix until a proper gasket was obtained.
Dutch
2001 GBM Landau 34' Class A
