Question About WG Pro Sensor
RJsfishin
Anyone know if the Pro Sensor uses DC current all the time ?
It has no off/on switch like the older power supply panel does.
The digital display times out, but I don't know how the power supply
could turn off.
Rich
'01 31' Rexall Vision, Generac 5.5k, 1000 watt Honda, PD 9245 conv, 300 watts Solar, 150 watt inv, 2 Cos 6v batts, ammeters, led voltmeters all over the place, KD/sat, 2 Oly Cat heaters w/ ox, and towing a 2012 Liberty, Lowe bass boat, or a Kawi Mule.
7 REPLIES 7
SoundGuy
wa8yxm wrote:
Re-reading this. The Sensar PRO sends power to the antenna unless you select CABLE. if you select CABLE then the sensar pro is basically OFF or as OFF as it gets.
The SensarPro goes into SLEEP mode after 3 minutes of no activation but is still drawing a minimal amount of power regardless of any mode it may be in so that when any button is later pushed it instantly activates. If you want draw to be zero then installing a kill switch in the +12 vdc feed to the SensarPro is the answer.
2012 Silverado 1500 Crew Cab
RJsfishin
wa8yxm wrote:
Re-reading this. The Sensar PRO sends power to the antenna unless you select CABLE. if you select CABLE then the sensar pro is basically OFF or as OFF as it gets . I'm not sure how OFF that is since it is a push button not a toggle.
But it sends power to the roof so if you have ANT selected (Any mode other than cable) it is using power.. But then if you go back to ye old wall plate.. Same thing.
You mite have something there...... switching to cable, didn't think of that.
Rich
wa8yxm
MEXICOWANDERER
Me too. I like my 0.000000 kWh consumption per decade for television watching ๐Ÿ™‚
RJsfishin
Being a 100% dry camper, any bit of power consumption is always a concern.
Of course a switch can be installed,.....so I guess my question should have been, why isn't there a switch ? I doubt that the power supply can sense "no activity", and therefore does not shut down.
So maybe my question should be,....how much power does the power supply draw ?
I can't find the specs on it, but it seems like the standard panel ones draw near 1 amp. I don't know why winegard did not leave the red lite and switch on the sensor pro, except for saving a dollar ??
Rich
wa8yxm
I like that Sensar PRO.. makes a big difference in the amount of TV I can watch ๐Ÿ™‚
SoundGuy
Yes, but the SensarPro does go to sleep so power draw is minimal. If this is a concern for you just install a kill switch of your own, just as I did.
