Dougrainer posted a while back about fixing a door squeak. Ours tried to drive us crazy and really was bad.
I read Doug's post:
I know you believe it is the rubber. I work on motorhomes for a living and have for 38 years. I cannot remember the last time a door noise was caused by rubber on metal. The odds are you need to use lithium or white grease on the metal door latch mechanism. I have numerous customers that come in and state the same thing you state. I use white grease on the metal latch, we go for a test drive and the customer cannot believe it was such a simple fix. Doug
and when my rig came home I used lithium grease on the door latch mechanism. To my delight, the squeaking was totally gone.
Thanks Doug, that was the best advise I have seen in a long time!
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
