Step one.. Lay multiple towels on whatever is below warm air intake on A/C
Step 2: Shut off
Step 3: Remove filters, clean and replace
Step 4: Turn back on
At any point where you feel it is proper either return towels to storage or hang up to dry.,
Option 2 Water normally drips from some point on the A/C onto the roof.. I have two A/Cs one drips off the back the other the driver's side.
If the RV is not level but slightly tilted the wrong way this can result in the inside edge of the drip tray being higher than the drip lip.. And dripping.
NOTE Water dripping off the evaporator colis into the drip tray is NORMAL.
