Easy Water Heater Drain cock removal.
danly
Need Ideas on removing broken drain cock on water heater. Threads OK severely corroded with scale.
Dan and Twi
2018 Coachmen Catalina Legacy 323BHDSCK
2003 SILVERADO HD 2500
"http://www.wunderground.com/US/MN/Minneapolis.html">
12 REPLIES 12
calamus
I put a 1/2 brass nipple and a FIP X Garden hose thead adapt then just a brass cap with a rubber washer no different that unscrewing a garden hose you can even put a bit of anti seize on the thread no tool required then.
2015 3500HD Chevy Dually Duramax, 2008 Sundance 2014 22'SSX bennington pontoon
Captain_Obvious
I have always wondered the same thing. I hate having to use a pair of pliers to mangle the plug out. In my internet searching, I came across this: Camco 11633 Water Heater Drain Plug and Wrench Kit
Looks interesting, but some of the reviews leave me skeptical.
John_Joey
danly wrote:
Its a brass fitting with a drain cock on it, which is stripped.
Without seeing what you got, I'll make a few statements hoping they will help.
First, that is not a standard setup and I would discard it. If it is an atwood I would go back to a plastic plug, or if suburban then a zinc rod.
Second, brass doesn't corrode so I'm guessing it's the petcock that is steel and a mess. If that is the case leave the petcock alone and just pull the brass plug and throw the whole thing away. Go back to the OEM for your hot water heater.
Thereโ€™s no fool, like an old fool.
westend
Does the fitting have six sides? Use a deep well socket. If the fitting is round, use a basin wrench. If both of those don't work, you'll need to drill and use an easy out or tap threads and use a threaded fastener. Heat may be a good friend, heating the fitting with a torch will release the rust between the two metals.
'03 F-250 4x4 CC
fischer
Go to the auto parts store and buy a easy out tool
2016 Winnebago 35B v10
2006 Jeep Liberty 4x4
Blue ox Tow Bar
danly
Dan and Twi
martipr
When you get it out you might want to consider this
Old Navy Chief (AOC) Retired Aircraft Mechanic/Inspector
2007 29' 27FBV Trail Bay V Series
2015 Dodge Ram 2500 Crew Cab 6.7 Cummins Diesel
Reese Strait-Line Dual Cam Hitch
bob213
If it's the plastic plug you can drill a hole in it and use a sprinkler nipple removal tool to turn it out.
You can avoid reality, but you cannot avoid the consequences of avoiding reality โ€“ Ayn Rand
Golden_HVAC
Dick_B wrote:
Once out replace it with the usual plastic (pvc?) plug with teflon tape on the threads. The Heater tank should be flushed out at least once per year which requires the removal of the plug and use of a `wand' to be effective.
I agree with only using plastic replacement plug. Also make SURE That you do not overtighten the plug.
I turn mine in hand tight, with two layers of teflon tape, and then snug it with a wrench only about 1/2 turn. This makes it easy to remove. If it drips, then tighten another 1/2 turn just until it stops. Remember you are only trying to hold back 40 PSI, and should be using a pressure regulator on the RV plumbing system.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline water
Escapees.com
Dick_B
Dick_B
2003 SunnyBrook 27FKS
2011 3/4 T Chevrolet Suburban
Equal-i-zer Hitch
midnightsadie
take wide blade screw driver heat and push in , some times you just take a sharp chisel and break it out ,be careful don,t hit the threads.when puting new one in rap threads with teflon tape and don,t over tighten.
Road_Runners
Is the drain plug broken or is it just stuck and won't come out? If it is stuck and won't come out it will usually break loose if you use a long handled breaker bar. I have a length of pipe that fits over my ratchet handle. Works every time.
'05' F-250 Power Stroke
'00' 30' Cameo Fifth Wheel
