โOct-16-2012 03:20 PM
โMay-19-2013 08:33 PM
โMay-19-2013 08:09 PM
โMay-19-2013 08:06 PM
bigfootford wrote:
I use this device for testing... It provides about a 13 amp load.
โMay-19-2013 07:45 PM
โMay-19-2013 06:05 PM
Salvo wrote:
BTW, I'm up the coast from you in Goleta. Today is a great sunny day to run solar tests. Will be looking forward for further results.
โMay-19-2013 05:21 PM
Salvo wrote:Refugio? Just got back from Point Mugu SB. AWESOME weather, perfect for solar.
โMay-19-2013 04:58 PM
DSchmidt_2000 wrote:
I have not measured quiescent current draw of the unit 'officially' but the clamp on meter which has 10mA resolution is showing 20mA draw during standby/snooze.
Yeah, probably not so great due to me operating it really low in its power handling capability. I do have 2 qty 45W panels though I'm only using one right now, but one of the tests I want to do is compare the charging amps with the panels in parallel vs in series going through the MPPT controller, and also vs in parallel going through a PWM controller or direct to the battery.
โMay-19-2013 03:16 PM
โMay-19-2013 03:13 PM
HiTech wrote:
It would be worth running your battery down to 11 volts or so and running similar tests.
Jim
โMay-19-2013 02:58 PM
JiminDenver wrote:
The you tube video early in the thread pointed out the temp sensor in the case. I've seen the controller drop the amps from 12 to below 6 when the case heated up in direct sun and bring them back up once it was placed in the shade and cooled down. Too bad i didn't have a DVM on the battery to see what happened to the volts at the same time.
โMay-19-2013 02:56 PM
Did some testing today. (sorry for the data not being aligned- don't know how to post formatted text).
Setup:
45W 12V Solar Blvd panel with these specs
Maximum Power Voltage (Vmp): 18.0V
Maximum Power Current (Imp): 2.5A
Short Circuit Current (Isc): 2.73A
12V 35AH SLA battery which I depleted about 75% yesterday
Watt's-up meter in-line with the battery to measure current INTO the battery, battery voltage, and watts into battery.
DMM to measure the solar panel's voltage at the input of the MPPT controller.
I have Deans Connectors between the watts-up and the MPPT controller and between the solar panel and the MPPT controller so I can easily unplug things and make changes.
Testing: What I did was measure the current going into the battery if the MPPT controller was "in-the-loop", and then connected the solar panel directly to the battery. With the Deans connectors, I could do this switch around in seconds.
Here are the measurements in order they were taken (if no measurement listed - then I forgot to write it down)
With the MPPT "in-the-loop"
Solar V Batt A Batt V Watts
16.76 3.08 12.51
17.00 3.05 12.51
Solar direct to battery
2.89 12.50V 35.5
17.05 3.02 12.51 37.4
16.94 3.07 12.52 37.1
2.93 12.51 35.7
The battery voltage and watts were from the Watt's-up meter - it has uncertainty in its measurements hence the watts reported are not exactly that calculated just doing the math.
I'm a bit disappointed to not have a much greater charging amps (only ~ 0.1A greater) given the delta between the battery and the panel is about 4V. Thinking that I may just be so low in power that I'm not in a high efficiency zone for this MPPT controller.
Putting my ear to the MPPT controller, I hear a regular 'ticking' noise. Will at some point drag out my digital scope and take some measurements to see what is going on.
โMay-19-2013 02:40 PM
Salvo wrote:
Thanks for the testing. The 0.1A gain compared to direct charge does seem quite low; especially when battery is at 12.5V. Is the controller's operating current high that it impacts your measurements? Perhaps using a panel that's greater than 100W will provide better results.
Sounds like there's a relay in your controller. It may be measuring open circuit voltage of the panel. Time to pull out the scope.
Sal
โMay-19-2013 11:00 AM
โMay-19-2013 10:05 AM
โMay-19-2013 09:53 AM
