โJul-01-2018 02:54 AM
โJul-02-2018 06:19 PM
โJul-02-2018 04:23 PM
MrWizard wrote:
really doesn't make any difference,if the dash A/C is rated 2500 more BTUs
that ability only extends into the cab area
the dash A/C does not move/cool the same amount of air as a roof top or basement A/C
it is not centrally located, it can not force cool air to the rear half of class A MH, it will cool the driving area and Maybe the sofa 'maybe'
a class C has a smaller cockpit area to cool, allowing for more cooling for the area behind the cockpit
simple 'BTU capacity' numbers do not tell the whole story
and a short class C, does not have nearly the cubic volume of space as a larger class A
โJul-02-2018 04:03 PM
โJul-02-2018 11:08 AM
wa8yxm wrote:
That said. Dash air is not big enough to cool off a 38' Motor home or for that matter a 15' motor home. when it's 90 out in the shade you got to run the roof air's no choice.
โJul-02-2018 10:43 AM
โJul-02-2018 05:31 AM
โJul-02-2018 03:30 AM
โJul-01-2018 06:36 AM
โJul-01-2018 06:13 AM
Kennyg wrote:
If you run the generator while driving what damage if any, occurs when the house A/C cycles off resulting in no-load on the generator??
โJul-01-2018 06:11 AM
โJul-01-2018 05:08 AM
โJul-01-2018 04:52 AM
โJul-01-2018 03:21 AM
โJul-01-2018 02:59 AM
