Oct-17-2015 09:04 PM
Oct-19-2015 01:02 PM
Oct-19-2015 06:50 AM
Oct-18-2015 10:40 PM
Oct-18-2015 10:11 PM
Oct-18-2015 09:50 PM
Oct-18-2015 04:17 PM
Oct-18-2015 04:12 PM
BTPO1 wrote:
I really wish that I was up in WA I would help you with your problem. Reading your last post I think that I would find someone with electrical knowledge to help you.
A continuity reading of "0" to "1" across a non-powered fuse would be normal. The reading of .25 is suspect to me and I would replace that fuse. JMO
Oct-18-2015 02:43 PM
Oct-18-2015 10:28 AM
turbojimmy wrote:filthy beast wrote:path1 wrote:
So in my limited elec knowledge I believe that circuit is not making a complete the circuit.
How exactly are you testing the page like clips. The power will come in from one side and out on the other so there should only be power on one side.
That's exactly what I was thinking. There should only be power on one blade. It would be unusual for that board to fail in that manner. Did you check for power at the fan? Or use your DVOM to make sure that you have a complete circuit across the blades for the fuse?
Oct-18-2015 09:47 AM
Jim-Linda wrote:
Check the lid pin on the fan. If it is sticking when the lid is up, no fan.
jim
Oct-18-2015 09:44 AM
MEXICOWANDERER wrote:
Roy Ken excellent points IMHO
Work totally powerless under independent lighting for safety.
No matter how simple or seemingly mundane TAKE IMAGES with your camera or smart phone.
Return and post on the forum. More experienced eyes will catch things your's cannot.
Return and post on the forum. More experienced eyes will catch things your's cannot.Return and post on the forum. More experienced eyes will catch things your's cannot.
Oct-18-2015 09:28 AM
RoyB wrote:
The 12VDC FUSE PANELS are PC TYPE CIRCUIT BOARDS with all of the components sockets etc soldered on them.
They can come unsoldered but that would be rare. Your problem is most likey where the screw connection is for the circuit wire that terminates on the board.
You need to remove the cover you are showing with your screw driver where you can see the screw down connections for the circuit wiring. Those connections can work loose real easy... They probably was not installed to tork spec at the factory.
Provide the model number of the distribution panel and perhaps you can find a photo of the exact 12VDC circuit board on-line to show how the external wires connect to it..
http://www.progressivedyn.com/pd5000_2.html is what I've found on-line so far. Good distribution but lacking info.
Be careful with the distribution panel as both 120VAC an 12VC wiring exists in close vicinity here...
Elec cord unplugged from house. Only elec I have to unit is 12 volt.
Typical 12VDC Fuse Panel Circuit board...
Roy Ken
Oct-18-2015 09:18 AM
westend wrote:
Typically, 12 V fuse panels have connectivity from the pack of the panel. It may be that your RV fuse panel is different and removing that screw provides access to the connections. My suggestion would be to remove the screw.
Oct-18-2015 08:43 AM
