Electric Awning Locks?
Curly2001
I am not sure if I have asked this before but here goes...
I have an electric Dometic awning on the 5th wheel. Years ago I had a manual awning that had the fabric rip on top where the sun had eaten up the fabric. When the fabric started to rip, of course we were on the road and the arms started to unroll. Caught it just in time to zip tie them back in place and somehow secured it to the side of the trailer.
My question is on the electric awnings, most are mounted flat to the trailer wall with no space to zip tie them if this happens again. Are there any locks available to keep them in place or what do we do if this happens? I think that if the fabric lets go the arms will free fall.
Thanks,
Curly
2019 Chev. Double cab 2500HD, 6.0, 4:10 diffs, six speed auto
2013 Heartland Sundance XLT 265RK
9 REPLIES 9
tarnold
Something else while your at it. During a recent sudden high wind, went to roll in the auto awning. The U- shaped storage arms didnโ€™t line up by about 1/4โ€œ ,at the top. Had to use a large screw driver to force them in to line up. Once home unfurled the awning and saw it had shifted all the way to one end, causing it to skew and wind up crooked tugging the arms so that they didnโ€™t line up. Lots of soapy water to lube and tug the 18โ€™ awning back in place on the roller tube. 2 stainless screws on each end should now hold it from shifting again.
Durb
I had an electric awning fail. The motor/gears output shaft has a flat where it is it is secured to the plastic roller cap. The plastic cap hogged out and gravity wanted the awning to stay in the open position. I rolled it up by hand an was able to tie it in place with some steel wire on the uprights to get me home. I also used some gorilla tape to hold it in place but feel it was overkill. This fail was the result of a poor design on a 2008 trailer. I'm hoping they have a solution installed by now.
Curly2001
Good idea, just looking at Murphy's law down the road sometime. I may look into the awning locks like mentioned above. Thanks again all.
Curly
dougrainer
Curly2001 wrote:
I am thinking that the fabric is the only thing holding the arms up since it is attached to the top of the trailer. If the fabric rips what will keep the arms from falling if they are not attached to anything?
Curly
This is true. But, the likelyhood of the complete fabric ripping away from the rail on an Electric is almost impossible. If you look, you can sometimes insert a nylon wire ties behind the arm even tho it is mounted to the sidewall. AND, at the top you can sometimes run the Wire tie around the upper arm area and around the tube ends. Doug
Curly2001
Curly
dougrainer
I have never seen a electric awning motor FAIL where it freewheeled. They always FAIL and lock up so the awning cannot unfurl or turn. Doug
RobWNY
Electric awnings aren't going to open up if the fabric has ripped. The motors failing would be the only way the arms would open up or if somehow the button to open the awning was pressed while traveling down the road. That issue you describe would be unique to manual awnings.
2020 Silverado 2500HD LT, CC, 4X4 6.6 Duramax
2021 Grand Design Reflection 311BHS
I asked him to do one thing and he didn't do any of them.
Curly2001
Thanks very much. I had hoped there was something out there.
Curly
IAMICHABOD
I have used RV awning Locks on my manual awning with great success.
He now makes them for powered awnings Here is what he has now.
2006 TIOGA 26Q CHEVY 6.0 WORKHORSE VORTEC
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
