โMay-20-2016 09:10 AM
โMay-23-2016 06:38 PM
pianotuna wrote:
My induction NuWave unit draws variable wattage. When it is first turned on it draws the maximum wattage--even if set to low. Once it reaches the set point temperature it cycles quite rapidly (too fast for a kill-a-watt meter) through various wattages.
You may find that a 1500 watt inverter might not be big enough to handle the induction cooker.
โMay-23-2016 06:14 PM
pianotuna wrote:
I can tell you that the NuWave 1300 watt will boil water faster than a 3000 watt traditional stove top burner.
โMay-23-2016 05:42 PM
MEXICOWANDERER wrote:But this is not what the OP is discussing. Yay for you, you can boil water faster than anyone on the forum.
http://www.agrisupply.com/carolina-cooker-single-burner-cast-iron-stove/p/56913/
This post got me curious about just how long it takes to boil water. This burner will take 22 oz of 60F water to boiling in 57 seconds. 15,000 BTU will do that ๐
On a range top, 5 qts of water takes 23 minutes to boil (covered). With this burner the water is boiling in 7 minutes. I heated an 14 quart pressure cooker with pot roast ingredients in 6 and a half minutes.
But most importantly, I have French Press coffee in my genuine "Wal-Mart Bubba" cup in under two and a half minutes.
No batteries required
The Keurig is not inferior - it is merely, uh, different. That, and what (35) different types of "coffee"?
โMay-23-2016 11:21 AM
westend, I certainly was not trying to "sway" the OP. But even a pure resistance of nichrome seems to incur an inrush. My exotic habit of disassembling a subject allows me to weigh all factors then come up with a plethora of permutations.
To set me engine back on the rails, the OP needs to actually MEASURE the voltage at the inverter studs when the Keurig is started. If the voltage remains above threshold value then the inverter becomes suspect ONLY WHEN AFTER the circuit breaker fasteners are examined and re-tightened.
Breakers are not eternal. After a few years the bi-metallic elements become annealed especially if they have carried a lot of current. Then there was my Mexico odyssey of a brand new box of 12 SIEMENS breakers that tripped at 13-amperes at 122 volts after 40-95 seconds of 13 ampere operation.
If when troubleshooting a troubleshooter relies on ASSumption then umption can be omitted.
Correctly administered tests using instrumentation will eliminate guesswork 100% of the time.
Hee hee
Paul Newman's, Blend and Dunkin' Donuts, blend are utterly safe and secure around me ๐
โMay-23-2016 11:16 AM
โMay-22-2016 05:37 PM
โMay-22-2016 05:36 PM
โMay-22-2016 05:34 PM
โMay-22-2016 05:30 PM
DrewE wrote:brulaz wrote:
It will be interesting to see whether this induction hot plate on the 800W setting can heat 1.7L of water faster than the propane burner. Of course on shore power we can bump it up to 1500W.
800W is equivalent to 2700 BTU/hr (in an energy sense). The propane burner will almost certainly be quicker, even taking into account the less efficient heat transfer. (RV stove burners typically are around 6500 to 10,000 BUT/hr.)
โMay-22-2016 03:30 PM
โMay-22-2016 02:47 PM
โMay-22-2016 08:52 AM
โMay-22-2016 04:13 AM
โMay-21-2016 07:05 PM
Brews One 8-ounce Cup in under Three Minutes, Single-use Water Reservoir
Mug Sensor - No Accidental Spills, No Glass Pots to Clean, Break or Crack
Easy Cleaning and Maintenance
No Coffee Grounds or Wet, Messy Filters
Energy Savings Mode - Automatic On/Off Function
Power: 700 watt
